INIPS
Subcase Information Entry The INIPS command can be used in the Subcase Information section to define initial plastic strains of elements for nonlinear static analysis.
INIPS = option
| Argument | Options | Description |
| option | <SID> No default  |
- INIPS Bulk Data Entries are not used unless selected in the Subcase Information section.
 - INIPS should only be selected by a nonlinear static subcase that is not continued from a preceding nonlinear subcase.
 - Plastic strain outputs for elements take into account both the initial plastic strain and the contribution from the deformation with loading.
