HEAT
I/O Options and Subcase Information Entry Used to output Joule loss density results in electrical analysis.
HEAT (format, group) = option
Definition
| Argument | Options | Description |
| format | <H3D, blank> Default = blank  |
| group | <PROP, COMP,
                                        SET, OPROP,
                                        OCOMP, OSET,
                                        blank>. 2 Default = blank  |
| option | <YES, ALL,
                        NO, NONE,
                    SID> Default = ALL  |
- Joule loss density result is output by default in electrical analysis.
 - The group argument is only supported for H3D output. If SET/OSET is requested a SID of Boolean SET with operator OR is expected in the field option. Elemental SETs referenced when using this option should have the OPERATOR field set to OR. Regular elemental SETs without Boolean OR are not allowed.
