GPKE
I/O Options and Subcase Information Entry The GPKE command can be used in the I/O Options or Subcase Information sections to request grid point kinetic energy output for normal modes subcases.
GPKE (format_list) = option
| Argument | Options | Description |
| format | <PUNCH, blank> |
| option | <YES, ALL,
                        NO, NONE,
                    SID> Default = ALL  |
- Grid point kinetic energy is written in % of the total kinetic energy of all grids in the structure. Therefore, GPKE results for each GRID are the same regardless of the requested option (ALL, YES, or SID).
 - If the coupled mass matrix is used (PARAM,COUPMASS,YES), the results at each GRID are influenced by all GRID connected to that GRID. Using a diagonal mass matrix formulation (PARAM,COUPMASS,NO) provides more meaningful results.
 - For large problems solved using EIGRA, run times increase if GPKE=ALL or a coupled mass matrix (PARAM,COUPMASS,YES) is specified, as the entire eigenvector for each mode must be calculated and stored.
