GPFOS
I/O Options and Subcase Information Entry Used to request fatigue factor of safety, hydrostatic pressure, and microscopic shear stress output for grid-based FATDEF for all subcases or individual subcases, respectively.
GPFOS (format, type, option) = option
| Argument | Options | Description |
| format | <H3D, OPTI, blank> |
| type | <SUB, EVENT, blank> |
| option | <HISTORY, blank> | Factor of Safety, Hydrostatic Pressure, and Microscopic Shear
                                Stress results are output as a function of time for Fatigue
                                subcases.
| option1 | <YES, ALL, NO,
                        NONE, SID,
                    PSID> Default = ALL  |
- When a FOS command is not present, fatigue FOS results are not output.
 - GPFOS output is available for fatigue subcases wherein the FATDEF entry references grid-based identification of fatigue domain.
 - Multiple formats are allowed on the same entry; these should be comma separated. If no format is specified, then this output control applies to all formats defined by OUTPUT or FORMAT commands for which the result is available. See Results Output by OptiStruct for information on which results are available in which formats.
 - Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
