FSI
Subcase Information Entry Identifies a FSI Bulk Data Entry to run Fluid-Structure Interaction Analysis with AcuSolve for a Linear Transient Heat Transfer Subcase or Nonlinear Direct Transient Analysis Subcase.
FSI = option
| Argument | Options | Description |
| option | <ID> No default  |
- The FSI Subcase Information Entry can only be added in Linear Transient Heat Transfer Analysis or Nonlinear Transient Analysis Subcases. This is only supported for Large Displacement Nonlinear analysis, and an error is issued if it is specified in a Small Displacement Nonlinear subcase.
 - Each FSI Bulk Data can only be referred to by a single supported subcase. Additionally, only one FSI Subcase Information Entry is allowed in any model (in other words, in models with multiple subcases, the FSI Subcase Information Entry can be specified in only one subcase).
