FREQUENCY
Subcase Information Entry The FREQUENCY command can be used to select the set of forcing frequencies to be solved in a frequency response problem.
FREQUENCY = option
- A frequency set selection is required for transient response by the Fourier transform method when TSTEP (FOURIER) is used. The Fourier transform will be performed at the frequencies specified.
 - All FREQi data with the same set identification number will be used.
 - If present above the first subcase, it is applied to each frequency response or transient subcase without a FREQUENCY command.
