Recover MBD Analysis Results
After MotionSolve is run, it is possible to recover displacements, velocities, accelerations, stresses, and strains for the flexbody in OptiStruct in order to create .op2 and .h3d results files for fatigue analysis.
The procedure is explained below.
ASSIGN,H3DMBD,30101,’pfbody_1_recov.h3d'
ASSIGN,H3DMBD,30102,’pfbody_2_recov.h3d'
ASSIGN,MBDINP,10,’pfbody.mrf'
Where, the 10
in the ASSIGN,MBDINP data
references the SUBCASE for which the MotionSolve results
will be used. In SUBCASE 10
, instead of performing a transient
analysis, OptiStruct will just use the results from
MotionSolve.
The 30101
and 30102
in the
ASSIGN,H3DMBD data refer to the Flex Body
ID's in the .mrf file.
OUTPUT OP2
OUTPUT H3D
ASSIGN,H3DMBD,30103,MBD_pfbody_BODY_2_PROP_6_recov.h3d
ASSIGN,H3DMBD,30102,MBD_pfbody_BODY_1_PROP_9_recov.h3d
ASSIGN,H3DMBD,30104,MBD_pfbody_BODY_3_PROP_10_recov.h3d
ASSIGN,MBDINP,1,MBD_pfbody_mbd.mrf
SUBCASE 1
TSTEP(TIME) = 4
DLOAD = 3
DISPLACEMENT = ALL
STRESS = ALL
SPC = 1
BEGIN BULK
GRID 9999999 $ Dummy GRID since at least one GRID is required
TSTEP 4 300 .0003333 1
TLOAD1 3 3 DISP 2
TABLED1 2 LINEAR LINEAR
+ 0.0 1.0 10.0 1.0ENDT
$ Dummy load on the dummy grid
SPC 1 9999999 1
SPCD 3 9999999 1 -200.0
ENDDATA
A dummy grid and a dummy load has been added for the OptiStruct analysis run.
