FATSDR
Bulk Data Entry Defines the solder joint for consideration in solder fatigue analysis.
| FATSDR | ID | SDRTYP | SIDPKG | SIDPCB | |||||
| DIM | PKGLEN | SDRTHK | DIAINFC | ||||||
| SOLDER | SDR1 | SDR2 | etc | etc | etc |
| ID | Entry identification
                                    number. Each FATSDR entry must have a unique ID. The FATDEF Subcase Information Entry may reference this ID. No default (Integer > 0)  |
| SDRTYP | Defines solder joint type.
                                Mandatory when the DIFFCTE method is used.
 No default  |
| SIDPKG | Element SET identification
                                number of the component. Mandatory when the DIFFCTE
                                method is used. No default (Integer > 0)  |
| SIDPCB | Element SET identification
                                number of the PCB. Mandatory when the DIFFCTE
| DIM | Optional continuation line indicating the dimension information follows. | |
| PKGLEN | Component length.
| PKGTHK | Solder thickness.
| DIAINFC | Joint diameter at the
                                    interface. Since it is used as a final crack length of solder joint in DARV method, the value is mandatory when DARV method is used. No default (Real > 0)  |
| SOLDER | Continuation line indicating the solder SETs follow. | |
| SDRi | Element SET of solder
                                    "i." No default (Integer > 0)  |
- For SDRTYP=XLEAD, two SDRi are expected. Otherwise, an error is issued during the run.
 - Fatigue load should be a static load with Thermal Expansion Coefficient when the DIFFCTE method is used.
 - Load History via the TABFAT entry is not allowed.
 - If DIM continuation line is not specified, OptiStruct will attempt to measure this from Finite Element Mesh data when the DIFFCTE method is used.
