The stress gradient effect is supported for both shells and solid elements. For solid
                elements, the stress gradient effect is only available with nodal evaluation and for
                shell elements, the stress gradient effect is only available with elemental
                evaluation.
            The Stress Gradient method is currently supported for Uniaxial and Multiaxial SN, EN
                with Time series loading. It is not supported for Dang Van FOS, Weld, Vibration, and
                Transient Fatigue analyses.
        FKM Guideline Method
            In the FKM guideline method, stress gradient effect is considered by increasing
                fatigue strength by a factor calculated using a rule in FKM guidelines. In HWTK GUI Toolkit implementation of FKM guideline method, 6 components of a
                stress tensor at each time step is reduced by the factor provided by FKM
                guidelines.
            To activate Stress Gradient effect using FKM guideline method, Stress Gradient should
                be set to FKM Guideline in SN/eN dialog. The equivalent stress σeq method
                to calculate stress gradient should be specified.
            The following steps are followed to reduce stresses at the surface to take stress
                gradient effect into consideration.
                    - Calculate stress gradient of 6 components of a stress tensor,
                            , at each time step after linear combination
                        of stress history. z-direction is an outward surface normal. For a solid
                        element, the gradient is calculated by finite difference between stress at
                        surface and stress at 1mm below the surface. The stress at 1mm below surface
                        is an interpolated stress from grid point stresses of an element of
                        interest. In case of 2nd order solid elements, only grid point
                        stresses at corners are used for interpolation. For shell elements, the
                        gradient is calculated from stresses of both layers and its thickness.
                    - Using the stress gradient obtained in Step 1, a gradient of equivalent
                        stress in the surface normal direction,
                            , is calculated in an analytical way at each
                        time step. The equivalent stress can be either von Mises stress or absolute
                        maximum principal stress.
                    - The related stress gradient,
                             is calculated using the following
                            normalization.
                    - Calculate the correction factor
                            . Refer to Correction Factor Calculation.
                    - Apply the correction factor
                             to the surface stress tensor to obtain
                        reduced surface stress. Apply the same
                             to corresponding strain tensor to obtain
                        reduced strain tensor when EN fatigue analysis is to be carried out with
                        nonlinear analysis.
            Correction factor calculation is based on relationship between
                     and
                     described in the FKM guidelines.
            According to FKM guidelines, the stress correction factor
                     is determined by:
                Table 1. Example values for Constants
                             and
                                | Constants |
                                Stainless Steel |
                                Other steels |
                                GS |
                                GGG |
                                GT |
                                GG |
                                Wrought Al-Alloys |
                                Cast Al- Alloys |
                                0.40 |
                                0.50 |
                                0.25 |
                                0.05 |
                                -0.05 |
                                -0.05 |
                                0.05 |
                                -0.05 |
                                2400 |
                                2700 |
                                2000 |
                                3200 |
                                3200 |
                                3200 |
                                850 |
                                3200 |
            Where,
                        - GS
                        - Cast Steel and Heat Treatable cast steel for general purposes.
                        - GGG
                        - Nodular Cast Iron.
                        - GT
                        - Malleable Cast Iron.
                        - GG
                        - Cast Iron with lamellar graphite (grey cast iron).
                     is UTS in MPa and dimension of
                     is mm. HWTK GUI Toolkit takes care of the
                unit system for
                     and
                     through stress units defined in
                    Material and stress unit and length unit defined in SN/eN
                dialog.
                     and
                     values are user input in
                    Material under FKM Stress Gradient tab of My
                    Material. Since the stress gradient has to be calculated in length
                dimension of mm, define the length units so that HWTK GUI Toolkit can
                properly locate a point that is 1mm below the surface. If
                     is negative,
                     is set to 1.0. If
                     is greater than 100 mm-1,
                     is set to 1.0 with a warning message.
        User-defined Relationship
            User-defined relationship between
                     and
                     can be specified through a TABLE
                (pairs of (xi,yi) = (
                    ) in My Materials. If
                     falls outside the range of xi,
                     will be extrapolated. This means that
                     can be lower than 1.0 when
                     is negative depending on how
                     is treated when being negative or greater than
                100mm-1. The user-defined relationship takes precedence over the one in FKM
                guidelines.
