Failsafe Topology Optimization
OptiStruct SPMD includes another approach for MPI-based parallelization called Failsafe Topology Optimization (FSO) for topology optimization of structures.
Regular Topology optimization runs may not account for the feasibility of a design in situations where a section of the structure fails. FSO divides the structure into damage zones and generates multiple models (equal to the number of failure zones), wherein each model is the same as the original model minus one failure zone. In this process, the FSO method is applied by running Topology Optimization simultaneously for all such generated models and a final design is output which is optimized to account for all generated models.
Typically, the number of damage zones is large, which means the number of SPMD domain is large. Such a job needs to be run on multiple nodes with cluster setup.
Activation
- The FAILSAFE continuation line on the DTPL Bulk Data
                    entry, the failsafe topology script run option (
-fso), and the number of processors (-np) can be used to activate Failsafe Topology Optimization. For example, /Altair/hwsolvers/script/optistruct filename.fem-np 20 -fso.Note: The option for executable, which is equivalent to script option-fso, is-fsomode. - The number of processors should be set equal to the number of damage zones in the original model
                    + 1. To determine the number of damage zones, you can run the Topology
                    Optimization model (with FAILSAFE continuation line) in
                    serial mode (or a check run) and look at the .out file. The
                    number of MPI processes for failsafe optimization is displayed in the
                        .out file. This determines the number of processors
-np) for the subsequent MPI (-fso) run.
Refer to Launch FSO for information on launching Failsafe Topology Optimization in OptiStruct.
Output
- Separate <filename>_FSOi folders are created for damage zone. Each folder contains the full topology optimization results for the corresponding model. For example, the folder <filename>_FSO1 would contain topology results (.out, .stat, .h3d, _des.h3d files, and so on) for the first damaged model (original topology model minus the first damage zone), and so on.
 - In the main working directory, the Damage Zones are output for both the first layer and the overlap layer (if it is not deactivated) to the <filename>_fso.h3d file. The Damage Zones can then be visualized in HyperView.
 - Additionally, in the main working directory, the final Failsafe Topology Optimization results are output to the <filename>_des.h3d file. It is recommended to compare these results with the initial non-Failsafe Topology results to get a sense of the modified design.
Supported Solution Sequences
- Both Shell and Solid elements are currently supported.
 - Multibody Dynamics (OS-MBD) is currently not supported.
 - FSO currently cannot be used in conjunction with the Domain Decomposition Method (DDM).
