Bulk Data Entry Defines boundary connections for an external superelement.
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | EXTRN |
                                GID1 |
                                C |
                                GID2 |
                                C |
                                GID3 |
                                C |
                                GID4 |
                                C |
                                GID5 |
                                C |
                                etc |
                                etc |
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | EXTRN |
                                1001 |
                                123 |
                                1002 |
                                456 |
                                1103 |
                                1234 |
                                434 |
                                123456 |
                                1340 |
                                456 |
                                etc |
                                etc |
        Definition
                                | Field |
                                Contents |
                                SI Unit Example |
                                | GIDi |
                                Identification number of the GRID or SPOINT to which the
                                    external superelement will be connected. No default (Integer >
                                        0)  |
                                | Ci |
                                Component numbers. 4
                                            - GRID
                                            - The components refer to the coordinate system
                                                referenced by the grid points.
                                            - No default (0 < Integer ≤ 6)
                                            - SPOINT
                                            - Default = blank (blank or 0)
                    - EXTRN can only
                        be specified in partitioned Bulk Data sections and is ignored in the main
                        Bulk Data section.
                    - Connection grids must be specified
                        in the partitioned Bulk Data section following BEGIN
                        SUPER = SEID.
                    - Pairs of blank fields may be
                        entered to allow easier modification of the EXTRN entry.
                    - Embedded blanks are not allowed in
                        the fields.
