ESTATFORCE
I/O Options and Subcase Information Entry The ESTATFORCE command can be used in the I/O Options or Subcase Information sections to request electrostatic grid force and electrostatic resultant force output for all subcases or individual subcases respectively.
ESTATFORCE (format,list,group,ESET=esetid) = option
Examples
ESTATFORCE(H3D) = ALL
ESTATFORCE(OPTI,COMP,ESET=34) = 4
Definition
| Argument | Options | Description |
| format | <H3D, OPTI,
blank> Default = blank |
| group | <PROP, COMP,
OPROP, OCOMP, blank> 5 Default = blank |
| setid | <ALL,SID> |
| option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- When an ESTATFORCE command is not present, electrostatic grid force or electrostatic resultant force is not output. Electrostatic resultant force is only supported for ASCII formats output.
- Multiple formats are allowed on the same entry; these should be comma-separated. If no format is specified, this output control applies to all formats defined by OUTPUT or FORMAT commands for which the result is available. See Results Output by OptiStruct for information on which results are available in which formats.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
- Electrostatic grid force and electrostatic resultant force are only output for Electrostatic loadcases.
- Only one group argument is allowed on the same entry.
- The group argument is supported only for ASCII formats output. If there is a group argument in the entry and there is no OPTI format argument, OPTI format request is automatically turned on.
