ESLTIME
Subcase Information Entry The ESLTIME command can be used to select particular time steps for geometric nonlinear response ESLM optimization or Multibody Dynamics ESLM optimization.
ESLTIME = option
- Only one ESLTIME Subcase Information Entry can be present for each subcase. It can only be used in subcases that contain an MBD entry.
 - If the SID referenced by the ESLTIME Subcase Information Entry matches with the SID defined for an ESLTADD Bulk Data Entry, the information on this entry alone is selected. However, if an ESLTADD Bulk Data Entry does not exist with the referenced SID, then any ESLTIME Bulk Data Entries that have this SID will be selected.
