EDEM
Bulk Data Entry Defines the parameters required to activate coupling between OptiStruct and EDEM.
EDEM | ID | ||||||||
CONTROL | PERIOD | FILTER | |||||||
COUPLING | TYPE | ID | LABEL |
EDEM | 100 | ||||||||
CONTROL | 0.1 | 0.15 | |||||||
COUPLING | SURF | 2 | Surf_2 |
ID | EDEM
coupling definition identification number. No default (Integer > 0) |
CONTROL | Flag indicating that the coupling control parameters are to follow. | |
PERIOD | OptiStruct-EDEM coupling time-step. This is the simulation time between two
consecutive synchronization points between OptiStruct and EDEM. 6 <Blank, 0 < Real < TTERM> Default = TTERM/100.0 |
FILTER | Filtering interval by a time
period. This indicates the filtering interval for smoothing the
imported forces from EDEM. <Blank, Real > PERIOD> Default = PERIOD |
COUPLING | Coupling interface flag indicating that parameters to define the coupling interface are to follow (this continuation line can be repeated as required to define multiple coupling surfaces). | |
TYPE | Entity type used to define the
coupling interface.
No default |
ID | Identification number of the entity
defined in the preceding TYPE field. No default (Integer > 0) |
LABEL | Label of the coupling surface
geometry which is generated by OptiStruct and sent to EDEM during the initialization step
(optional). Default = coupling_<edemid>_interface_<surfid> (Character String) |
- OptiStruct-EDEM coupling allows coupling the advanced structural analysis capabilities of OptiStruct with bulk and granular material interaction capabilities of EDEM. You can simulate and analyze the interaction of materials such as coal, soils, grains, and so on with deformable surfaces. It is currently only supported with Explicit Dynamic Analysis (NLEXPL) subcases.
- OptiStruct transmits nodal coordinates and velocity to EDEM, while EDEM sends nodal forces to OptiStruct during the coupling, which occurs at each synchronization point after a time defined as the coupling time-step specified by the PERIOD field.
- It is important to make sure that the Unit Systems defined in both OptiStruct and EDEM are consistent. For OptiStruct-EDEM coupling runs, it is mandatory in OptiStruct to define the UNITS Subcase Entry to identify the model units. It is your responsibility to make sure that this identified units system is consistent with the units system defined in EDEM.
- The coupling interface surface is
defined only in OptiStruct and the first
equipment material data defined in the EDEM
model is used as the material data for all coupling surfaces defined by
OptiStruct. The coupling surface(s) defined
by OptiStruct are exported to the EDEM model during the initialization of coupling.
Additionally, the particle type, material, interaction physics data should
be defined in the EDEM model.
In OptiStruct, the interface surface material data is used to calculate the deformation behavior of surface, while in EDEM, the interface surface material data (defined under Equipment Material) is used to calculate the contact forces during the interaction between the particles and the surface.
- To initiate an OptiStruct-EDEM coupling run, the Coupling Server should be
started in the EDEM GUI, and the EDEM model should be loaded into the EDEM Creator GUI. Then check to make sure that the
“Current Time” is set to 0.0 in EDEM Creator
GUI. Subsequently, before the OptiStruct run,
include the path to *\EDEM\lib in the EDEM installation location to
$PATH
environment variable. Then run the OptiStruct model which contains the EDEM Subcase and Bulk Data Entries. - The coupling between OptiStruct and EDEM
involves synchronizing the simulation at specific intervals to exchange
relevant data (OptiStruct provides the Nodal
coordinates and Nodal velocities to EDEM, and
EDEM provides the Forces to OptiStruct at synchronization points). The figure
below provides more information on how the synchronization takes place.
- DT_user
- User-defined time between synchronization points specified in the PERIOD field, also identifies the OptiStruct-EDEM coupling time-step
- DT_os
- OptiStruct time-step
- DT_edem
- EDEM time-step
- DT
- Actual coupling time-step during the run
- tn
- The time at the nth synchronization point
- F
- Forces provided by EDEM
- X
- Nodal coordinates provided by OptiStruct
- V
- Nodal velocities provided by OptiStruct
- 1-9
- Numbers represent the steps which take place sequentially.
Figure 1. Note:- The actual value of DT can be slightly different between OptiStruct and EDEM (as the individual time-steps of each solver can be different from each other).
- The value of DT can also vary slightly during the course of the analysis within each solver (as the time-steps of each solver can vary adaptively during the course of the solution).
- It is not recommended to have the value of
PERIOD (DT_user) lower than either of the
individual solver time-steps (DT_os or D_edem). In case the
value of PERIOD is set lower than one or both
of the individual time-steps, it is reset by OptiStruct at cycle 2 of the Explicit run
based on the below formula:
DT_user = max (DT_user, 2*DT_os, 2*DT_edem)
This reset is performed only once during the coupling run, and in the rare case that the value of DT_user falls below the value of either of the individual solver time-steps subsequently during the course of the coupling run, the synchronization occurs at the next/upcoming solver time-step.
