DVMBRL2
Bulk Data Entry Relates a design variable to properties of MBD entities using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
| DVMBRL2 | ID | PTYPE | BID/ EID  |
                            PNAME | EQID | ||||
| DESVAR | DVID1 | DVID2 | DVID3 | DVID4 | DVID5 | DVID6 | DVID7 | ||
| DVID8 | DVID9 | etc. | |||||||
| DTABLE | LABL1 | LABL2 | LABL3 | LABL4 | LABL5 | LABL6 | LABL7 | ||
| LABL8 | etc. |
| ID | Relationship identity. ID
                                must be unique with respect to other DVMBRL1 and
                                    DVMBRL2 cards. No default (Integer > 0)  |
| TYPE | Property type to be
                                related. 1 No default (Character)  |
| BID/EID | Body ID or Element ID
                                number. When TYPE is PRBODY,
                                this field is the ID number of a rigid body. When
                                    TYPE is CMBUSH(M),
                                    CMBEAM(M), or CMSPDP(m), this
                                field is the ID number of a corresponding element. No default (Integer > 0)  |
| PNAME | Property name, such as "A"
                                or "L" (as in the documentation of the PRBODY,
                                    CMBEAM(M), CMBUSH(M), and
                                    CMSPDP(M) cards). No default (Character or Integer > 0)  |
| EQID | Equation ID of
                                    DEQATN data. No default (Integer > 0)  |
| DESVAR | Indicates DESVAR ID numbers follow. | |
| DVIDi | DESVAR
                                    ID. No default (Integer > 0)  |
| DTABLE | Indicates DTABLE labels follow. | |
| LABLi | Constant label on
                                    DTABLE card. No default (Character)  |
- Property type table:
- PRBODY
 - IXX
 - IYY
 - IZZ
 - IXY
 - IXZ
 - X
 - X component of center of gravity.
 - Y
 - Y component of center of gravity.
 - Z
 - Z component of center of gravity.
- CMBEAM/CMBEAMM
 - L
 - Undeformed length along the X-axis of the beam.
 - A
 - Area of the beam cross-section.
 - I1
 - Area moment of inertia in plane 1 about the neutral axis.
 - I2
 - J
 - Torsional constant.
 - K ~ K
 - Area factor for shear.
- CMBUSH/CMBUSHM
 - K ~ K
 - Translational stiffness.
 - K ~ K
 - Rotational stiffness.
 - B ~ B
 - Translational damping.
 - B ~ B
 - Rotational damping.
 - P ~ P3
 - Translational preload.
 - P4 ~ P6
 - Rotational preload.
- CMSPDP/CMSPDPM
 - K
 - Stiffness
 - B
 - Damping
 - L
 - Unstretched length of spring damper.
 - PF
 - Preload force.
 - This card is represented as an optimization design variable property relationship in HyperMesh.
