DRESPONSE
I/O Options and Subcase Information Entry The DRESPONSE command can be used in the I/O Options section to request Design Response Output for optimization runs. The DRESP1, DRESP2, and DRESP3 responses in the model are output as contours in the H3D file.
DRESPONSE (type) = option
| Argument | Options | Description |
| type | <EQUA> |
| option | <YES, NO> |
- The DRESPONSE entry can be used to control the output of Design Responses (DRESP1, DRESP2, and DRESP3) to the H3D file.
 - All grid-based and element-based responses (DRESP1) are supported, and additionally all such combinations (DRESP2 and DRESP3). The remaining responses are not supported since contouring them in HyperView is not possible.
 - Responses are output inside the corresponding (for example, DISP responses are output in their corresponding static . For frequency response optimization, responses are output inside the appropriate loading frequency). Global responses are output in a separate global (_glob.h3d file for the default BYSUB output).
 - DRESPONSE(EQUA) can be used to disable the output of DRESP1 responses. Only DRESP2 and DRESP3 responses are output.
 - User-defined responses that spawn multiple responses internally are not supported, since the response ID and label are not unique.
