DOPTPRM
Bulk Data Entry Defines design optimization parameters by overriding the defaults.
| DOPTPRM | PARAM1 | VAL1 | PARAM2 | VAL2 | PARAM3 | VAL3 | PARAM4 | VAL4 | |
| PARAM5 | VAL5 | etc. |
| DOPTPRM | MINDIM | 10.0 | OBJTOL | 0.01 |
| Field | Contents |
| PARAMi | Parameter name. See below for valid names. |
| VALi | Parameter
                                    value. (Real, Integer, or Label)  |
- Some of the parameters may also be defined as separate entities in the I/O section of the deck, using the Previous (OS3.5) Input Format. Only one definition is allowed.
 - This card is represented as an opticontrol in HyperMesh.
Supported Parameters
The available parameters are listed below. Click the parameter name for detailed parameter descriptions.
