DOPTPRM, BKLOCAL2
Bulk Data Entry Specifies the maximum number of elements to represent the buckling zone for local modes.
| Parameter | Values | Description |
| BKLOCAL2 | <Integer ≥ 0> No default  |
                            If the size of the
                                buckling zone (determined by BKLOCAL1), for any
                                modes, goes over the specified number of elements, then they will be
                                considered as global buckling modes. The constraint bound for local mode will be specified in 6th field of DCONSTR.  |
