DOPTPRM, BKLOCAL1
Bulk Data Entry Determines the buckling zone of the model.
| Parameter | Values | Description |
| BKLOCAL1 | <0.0 ≤ Real ≤
                                    1.0> Default = 0.5  |
                            Any grids with
                                eigenvectors greater than the specified value
                                    (BKLOCAL1*largest eigenvector) are considered
                                as the buckling zone. The constraint bound for local mode will be specified in 6th field of DCONSTR.  |
