.disp file
The .disp file is an OptiStruct ASCII format results file.
File Creation
This file is created when the OPTI, OS or BOTH formats are chosen. (See documentation for the I/O Option OUTPUT).
File Contents
Result | Description |
Acceleration | Acceleration results from
frequency response analysis and linear transient analysis. Output is controlled by the I/O Option ACCELERATION. |
Displacement | Displacement results from
linear static, inertia relief, frequency response analysis, and
linear transient analysis. Output is controlled by the I/O Option DISPLACEMENT. |
Eigenvector | Eigenvector results from
normal modes and linear buckling analysis. Output is controlled by the I/O Option DISPLACEMENT. |
Velocity | Velocity results from
frequency response analysis and linear transient analysis. Output is controlled by the I/O Option VELOCITY. |
File Format
The displacement file has the following format:
For each iteration, the following header is used: | |||||
iter | Iteration | Numids |
- Data
- Description
- iter
- Keyword identifying that the next field is the iteration number.
- Iteration
- The iteration number.
- Numids
- The number of linear static subcases plus the number of calculated normal and buckling modes.
Within the iteration section, the following header is used for each linear static subcase, normal or linear buckling mode, or direct modal frequency response: | |||||
LCID | Numnod | Freq | Result: SPCcase (Datatype) |
- Data
- Description
- LCID
- Output ID for the subcase or mode. This is not necessarily the same as the subcase ID defined in the input data.
- Numnod
- Number of grids in the model.
- Freq
- Frequency or Buckling eigenvalue (1.0 for static subcases).
- Result
- Keyword declaring the result type given.
- SPCcase
- SPC set identification number for linear static, inertia relief, or frequency response subcases or 1 for eigenvectors.
- Datatype
- Keyword indicating the type of subcase involved.
Within the subcase or mode section, the following information is provided for each node: | |||||
NID | X disp | Y disp | Z disp |
- Data
- Description
- NID
- Node identification number.
- X
- X displacement of the node.
- Y
- Y displacement of the node.
- Z
- Z displacement of the node.
The displacement file has the following format for linear transient analysis:
iter | Iteration |
- Data
- Description
- iter
- Iteration
Within the iteration section, the following header is used for each transient analysis subcase: | ||||
Subcase | Id | Label | ||
Time | Time | |||
Result Type | Domain | [Format] |
- Data
- Description
- Id
- Output ID for the subcase. This is not necessarily the same as the subcase ID defined in the input data.
- Label
- Subcase label.
- Time
- Time increment information.
- Format
- Complex, Real, Imaginary, Phase, and so on.
- Result Type
Within the subcase section, the following information is provided for each grid: | |||||||
GID | X | Y | Z | RX | RY | RZ |
- Data
- Description
- GID
- Grid identification number.
- X
- X value of the grid.
- Y
- Y value of the grid.
- Z
- Z value of the grid.
- RX
- RX value of the grid.
- RY
- RY value of the grid.
- RZ
- RZ value of the grid.
- The I/O Option Previously Supported Results controls the frequency of output for analytical results during an optimization.
