DGLOBAL
I/O Options and Subcase Information Entry The DGLOBAL command can be used in the I/O Options section to activate the Global Search Option (GSO).
DGLOBAL = n
| Argument | Options | Description |
| n | (Integer > 0) No default  |
                            Identification of a DGLOBAL Bulk Data Entry. |
- This command must reference a DGLOBAL Bulk Data Entry to run GSO.
 - This data can exist only once in the I/O section.
 - This command activates a global search algorithm to run an optimization of user-defined design variables from multiple starting points.
