DEFORM
Subcase Information Entry The DEFORM command can be used to select an element deformation set.
DEFORM = option
| Argument | Options | Description |
| option | <SID> |
- Only one DEFORM entry can be defined for each subcase.
 - If present above the first subcase, it is applied to all linear static, linear buckling, and nonlinear quasi-static (Gap/Contact) subcases.
