CYJOIN
Bulk Data Entry Defines points on one of the boundaries that connect to adjacent segments in cyclic symmetry analysis.
Format 1
CYJOIN | SIDE | GID1 | GID2 | GID3 | GID4 | GID5 | GID6 | ||
GID7 | GID8 | GID9 | etc. |
Format 2
CYJOIN | SIDE | GID1 | GID2 | THRU | GID6 |
Example 1
CYJOIN | 1 | 3 | 103 | 105 | 54 | 1130 | 1450 | ||
7 |
Example 2
CYJOIN | 2 | 2 | 23 | THRU | 27 | 122 |
SIDE | Side identification number. 3
No default (Integer) |
GIDi | Grid identification number. No default (Integer > 0) |
THRU | Keyword used for ID ranges to indicate that all IDs between
the preceding ID and the following ID are to be included in the
set. This is applicable only for Format 2. |
- CYJOIN and CYSYM Bulk Data Entries are required in cyclic symmetry analysis.
- Supported analysis types include linear static (STATIC), normal mode analysis (MODES) and implicit nonlinear (NLSTAT & NL-DTRAN) analyses, and prestressed analyses are supported with STATSUB(PRELOAD).
- Two homologous CYJOIN entries should be defined respectively for both SIDE 1 and SIDE 2 of a segment. Each grid on a CYJOIN entry should be paired with a matching grid on the other entry. Mismatched grid pairs would result in loss of accuracy, and in such cases a warning that lists mismatched grids will be printed to the .out file.
- The two cyclic boundaries of the
modeled segment which are to be connected to adjacent segments are defined
as SIDE 1 and SIDE 2. The positive
direction of the axis of symmetry is defined such that
SIDE 1 and SIDE 2 are numbered
sequentially in the counter clockwise order about the axis.
Figure 1. Axis of symmetry and cyclic boundaries of the basic segment - The axis of cyclic symmetry is
determined by the geometry and CD fields of the first
pair of grids appearing on CYJOIN entries. Hence, the
displacement coordinate systems (the CD field on GRID Bulk Data Entry) of the first grid pair should
be consistent between the CYJOIN entries. This
requirement could be easily satisfied by using a spherical or cylindrical
coordinate system placed on the axis of symmetry. An example of consistent
rectangular coordinate systems for CYJOIN is illustrated
in Figure 2.
Figure 2. Illustration of consistency of the coordinate systems for CYJOIN - If PARAM, AXCYSYM, YES is present, the axis of symmetry will be defined by grids on the CYAX entry, and the restrictions in Comment 5 regarding the CD fields of grids on CYJOIN no longer apply. Refer to PARAM, AXCYSYM for more details.
- At the segment interfaces, all components of displacement at GIDi are constrained to adjacent segments during the analysis, except those constrained by SPC, or assigned dependent by MPC, RBE2 and RBE3.
