CVISC
Bulk Data Entry Defines a viscous damper element.
| CVISC | EID | PID | G1 | G2 |
| CVISC | 2 | 64 | 12 | 63 |
| EID | Unique element identification
                    number. No default (Integer > 0)  |
| PID | A PVISC entry identification
                                    number. Default = EID (Integer > 0)  |
| G1, G2 | Geometric grid point
                                identification numbers of connection points. No default (Integer > 0)  |
- G1 ≠ G2.
 - Only one viscous damper element may be defined on a single entry.
 - Viscous damper elements are ignored in heat transfer analysis.
 - This card is represented as a spring element in HyperMesh.
