CSUPEXT
Bulk Data Entry Defines the Exterior grid points for One-Step Superelement Analysis.
CSUPEXT | SEID | G1 | G2 | G3 | G4 | G5 | G6 | G7 |
Alternate Format
CSUPEXT | SEID | G1 | THRU | G2 |
CSUPEXT | 6 | 55 | 933 | 23 | 231 | 355 |
SEID | Superelement
identification number. No default (Integer ≥ 0) |
Gi | Grid or Scalar Point
identification numbers. Default = Blank (Integer > 0, or THRU) |
- If THRU option is used, then G1 should always be less than G2.
