The .cpr file is an OptiStructASCII format results file.
File Creation
This file is created when CONTPRM,PREPRT,YES is specified in an
input file which contains contact.
File Contents
This file contains a summary of initial conditions of contact interfaces. The
information is printed as a separate table for each contact interface in the model.
Currently, .cpr file output is supported for any model with
contact.
File Format
The following table format is used to print the initial contact summary
information.
Name
Content
NA
Contact Interface (N2S/S2S)
Lists the ID and name of the Contact Interface
NA
Secondary SURF/SET
Lists the ID and name of the Secondary in the Contact
Interface
NA
Main SURF/SET
Lists the ID and name of the Main in the Contact
Interface
(I) - Integer
CONTID
Contact interface ID
(I) – Integer
SLVGID
Core secondary grid ID of the gap
(I) – Integer
NCMSTG
Number of connected main grids of the gap
(I) – Integer
NCSLVG
Number of connected secondary grids beside the core secondary
grid of the gap (only for S2S contact)
(C) - Characters
STATUS
Gap status (OPEN/CLOSED/FROZEN)
(R) - Real Number
OPENING
Gap opening (negative value means penetration)
(R) – Real Number
RAWGAP
Raw gap opening based on mesh coordinates (adjusted mesh
coordinates with N2S ADJUST)
(R) – Real Number
PADDING
Gap padding due to GPAD, S2S ADJUST, CLEARANCE, etc.
(R) – Real Number
SAREA
Nodal contact area on the core secondary grid (only for S2S
contact)
