Penalty-based Contact
The majority of contact implementation within OptiStruct involves the penalty-based process.
This can be activated using the CONTACT (PCONT, if necessary) and TIE Bulk Data Entries. The TIE entry supports both Penalty-based and Lagrange Multipliers-based formulations. Both Node-to-Surface (N2S) and Surface-to-Surface (S2S) discretization methods utilize this process to implement contact between parts. The discretized contact elements are assigned variable stiffness values (penalties) depending on the proximity of the contact surfaces to each other and the type of contact forces on the element. The primary purpose of the variable stiffness values is to minimize penetration of the contact surfaces.
The stiffness of each contact element typically depends on the type of analysis, linear or nonlinear, that is performed. For Linear Analysis, the contact stiffness is constant throughout the solution. The contact stiffness depends on the initial state of the contact. If the contact is initially open, it remains open for the duration of the run. The same goes for closed contacts. The contact status or the contact stiffness values are not updated during the course of the solution for linear runs. The initial contact stiffness of each contact element depends on the initial contact gap opening distance (U0), which is calculated based on the positions of the Secondary and Main (including contributions from the GPAD field, if any). For open contact elements, a very small stiffness value of KB=10-14 * STIFF is used to avoid numerical singularities.
Figure 1. Penalty-based Contact Element Force-Displacement Curves for Linear Analysis
