Output from Contact Analysis
The CONTF I/O Options and Subcase Information Entry can be used to request contact results output for all nonlinear analysis subcases or individual nonlinear analysis subcases, respectively.
The NLOUT entry can be used to request incremental output from a Nonlinear Analysis. Additionally, if an NLOUT entry is specified in the model (and referenced in a subcase), then OptiStruct outputs, by default, for large displacement nonlinear analysis, the history of strain energy and contact stabilization energy to data files which can be plotted with HyperGraph. The HyperGraph main file is entitled filename_nlm.mvw and the HyperGraph data files (in ASCII format) are entitled filename_e.nlm.
Contact Shear Utilization Output
Contact shear utilization factor and shear magnitude output is available via the CONTF output request. Shear magnitude is the summation of grid shear force.
Shear Utilization factor is given by:
Shear utilization factor (U) is a quantitative measure for determining the load increment at which sliding has occurred (if any). When the utilization factor gets closer to one, sliding occurs.
- Result Type
- Comments
- Shear utilization factor
- It is available only in H3D and OPTI formats. In H3D format, it is output on each node. In OPTI format, it is output for each contact interface.
- Shear magnitude
- It is output for each contact interface and is available only in OPTI format.
