CONROD
Bulk Data Entry Defines a rod element without reference to a property entry.
| CONROD | EID | G1 | G2 | MID | A | J | C | NSM |
| CONROD | 2 | 16 | 17 | 4 | 269 |
| EID | Unique element
                                identification number. (Integer > 0)  |
| G1,G2 | Grid point identification
                                numbers of connection points. (Integer > 0; G1 ≠ G2)  |
| MID | Material identification
                                number. 1 (Integer > 0)  |
| A | Area of the
                                    rod. (Real)  |
| J | Torsional
                                    constant. (Real)  |
| C | Coefficient for torsional
                                stress determination. (Real)  |
| NSM | Nonstructural mass per
                                unit length. (Real)  |
- For structural problems, MID may reference only a MAT1 material entry.
 - In case of plasticity problems, MATS1 can be referenced with the same ID as MAT1 in small displacement and large displacement nonlinear analysis. The plasticity behavior is considered only in the axial direction, and the torsional behavior remains elastic.
 - For heat transfer problems,
                        MID may reference only a MAT4 material entry.
Figure 1. CONROD Element Forces and Moments  - This card is represented as a rod element in HyperMesh.
