CONM2
Bulk Data Entry Defines a concentrated mass at a grid point of the structural model.
Attention: Valid for Implicit
                    and Explicit Analysis
| CONM2 | EID | G | CID | M | X1 | X2 | X3 | ||
| I11 | I21 | I22 | I31 | I32 | I33 | ||||
| RAYL | ALPHA |
| CONM2 | 2 | 15 | 49.7 | ||||||
| 16.2 | 16.2 | 7.8 |
| EID | Unique element
                                identification number. No default (Integer > 0)  |
| G | Grid point identification
| CID | Coordinate system
                                identification number. Default = 0 (Integer ≥ -1)  |
| M | Mass value. No default (Real)  |
| X1, X2, X3 | Offset distance from the
                                grid point to the center of gravity of the mass in the coordinate
                                system defined by CID, unless
                                    CID = -1, in which case
                                X1, X2, and
                                    X3 are the coordinates (not offsets) of the
                                center of gravity of the mass in the basic coordinate
                                    system. Default = 0.0 (Real)  |
| Iij | Mass moments of inertia
                                measured at the mass center of gravity.
| RAYL | Continuation line flag for material-dependent Rayleigh damping 5 | |
| ALPHA | Rayleigh damping
                                coefficient for the mass matrix 5 Default = 0.0 (Real ≥ 0.0)  |
- If the continuation is omitted, all rotary inertia is assigned zero values.
 - The form of the inertia matrix about its
                    center of gravity is:Where,
- M
 - Input mass value
 - Iij
 - Input inertia values
 - X1, X2, and X3
 - Offsets
 - If CID = -1, the offsets are computed internally as the difference between the grid point location and X1, X2, and X3. The grid points may be defined in a local coordinate system, in which case the values of must be in a coordinate system that parallels the basic coordinate system.
 - If CID > 0, then X1, X2, and X3 are defined by a local Cartesian system, even if CID references a spherical or cylindrical coordinate system.
 - For material-dependent Rayleigh
                    damping, the equivalent viscous damping,
                        , is defined as:Where,
- Defined on the RAYL continuation line on the material entry
- Mass matrix
- Nonlinear Transient Analysis
 - This card is represented as a mass element in HyperMesh.
