CNTLCK
Subcase Information Entry Used for preloading a Nonlinear Static Analysis subcase to activate a contact lock for the corresponding preloaded Linear Analysis subcase.
Note: The contact lock is only applied to the preloaded Linear Analysis subcase.
CNTLCK=option
| Argument | Options | Description |
| option | <SID> No default  |
- The CNTLCK Subcase Information Entry should be specified in the preloading of a Nonlinear Static Analysis subcase.
 - For more information on preloading, refer to Prestressed Linear Analysis in the User Guide.
