CMBUSHT
Bulk Data Entry Defines a bushing element without reference to a property entry.
| CMBUSHT | EID | G1 | G2 | X1, G3 | Y1 | Z1 | |||
| "K" | K1TID | K2TID | K3TID | K4TID | K5TID | K6TID | |||
| "B" | B1TID | B2TID | B3TID | B4TID | B5TID | B6TID | |||
| "P" | P | P | P3 | P4 | P5 | P6 |
| CMBUSHT | 4 | 1 | 2 | 1.0 | 0.0 | 0.0 | |||
| K | 100 | 100 | 100 | 1 | 1 | 1 | |||
| B | 1 | 1 | 1 | 1 | 1 | 1 | |||
| P | 0 | 0 | 0 | 0 | 0 | 0 |
| EID | Unique element
                                identification number. (Integer > 0)  |
| G1 | Grid point identification
| G2 | Grid point identification
| G3 | Grid point identification
                                number to optionally supply X1,
                                    Y1, and Z1 in conjunction
                                with G1. (Integer > 0)  |
| X1, Y1, Z1 | Orientation vector of the
                                    bushing. (Real)  |
| K | Stiffness specifier. | |
| K1TID, K2TID, K3TID | Translational stiffness
                                    TABLEDi ID. Default = 0 (Integer ≥ 0 or blank)  |
| K4TID, K5TID, K6TID | Rotational stiffness
| B | Damping specifier. | |
| B1TID, B2TID, B3TID | Translational damping
| B4TID, B5TID, B6TID | Rotational damping
| P | Preload specifier. | |
| P, P, P3 | Translational preload. | |
| P4, P5, P6 | Rotational preload. |
- This card is represented as a spring element in HyperMesh.
