CHECK
I/O Options and Subcase Information Entry The CHECK command can be used in the I/O Options section to request that only a model check be performed.
CHECK
- The CHECK entry performs a model check
                    only (even if the
-analysisrun option is used). - If this keyword is present, only the subroutines which read in the input files are executed. A report that provides information on errors in the model and the memory and disk space requirements is given.
 - Useful for large runs since the amount of memory and time required to perform this function is very small.
