CFASTG
Bulk Data Entry Defines a fastener which can be used to model connections such as spot welds, rivets, bolts and so on.
| CFASTG | EID | PID | ELSET | REFNODE | CID | INFLRAD | SRCHRAD | ||
| ADJUST | WTMETH | PJID | |||||||
| SURF | ID1 | ID2 | ID3 | etc. |
| CFASTG | 22 | 1 | 17 | 2.5 | 10.0 | ||||
| YES | UNIFORM | ||||||||
| SURF | 31 | 32 |
| EID | Unique element
                                    identification number.  No default (Integer > 0)  |
| PID | Identification number
                                    of a PFASTG entry.  No default (Integer > 0)  |
| ELSET | (Optional) References
                                    a JOINTG element ID if this fastener is
                                    modeled explicitly by JOINTG elements.
                                         Default = Blank (Integer > 0)  |
| REFNODE | (Optional)
                                    Identification number of a GRID SET ID which defines the
                                    positioning nodes used to define the fastener and to generate
                                    internal JOINTG elements. This field can be
                                    used together with PJID to assign
                                        PJOINTG to internally created
                                        JOINTG elements. Default = Blank (Integer > 0)  |
| CID | Identification number
                                    of the coordinate system for this CFASTG
                                    fastener. If this coordinate system field is not defined, an
                                    internal coordinate system is generated based on the positioning
                                    point and surface that the positioning point projected on.
| INFLRAD | Maximum distance from
                                    the projection point on the fastener surface within which the
                                    grids on the surface should lie to be used to generate the
                                    internal RBE3 elements.  No default (Real > 0.0)  |
| SRCHRAD | (Optional) Search
                                    radius from the positioning point to find the fastening points
                                    on the surfaces. Default = Blank (Real > 0.0)  |
| ADJUST | Controls the
                                    adjustment of local Z direction of CID.
| WTMETH | Controls how the
                                    weights are calculated for internally generated
                                        RBE3 elements.
| PJID | (Optional)
                                    Identification number of a PJOINTG entry.
                                    This field can be used in conjunction with the
                                        REFNODE field to assign
                                        PJOINTG property to internally generated
                                        JOINTG elements. If this field is not
                                    defined, the JOINTG entries are defined with
                                        RBEAM type.  Default = Blank (Integer > 0)  |
| SURF | Continuation line flag to define the surfaces to be connected by CFASTG. The surface IDs are to follow. | |
| IDi | Define the surfaces to
                                    be connected by this CFASTG entry. These
                                        IDi refer to the identification numbers
                                    of SURF Bulk Data Entries.  No default (Integer > 0)  |
- The CFASTG entry is used to define a fastener connection between two surfaces.
 - The CFASTG
                        entry is currently supported for:
- Nonlinear Implicit Analysis
 - Explicit Dynamic Analysis
