CDAMP3
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points.
| CDAMP3 | EID | PID | S1 | S2 |
| CDAMP3 | 16 | 978 | 24 | 36 |
| EID | Unique element
                                identification number. No default (Integer > 0)  |
| PID | A PDAMP property entry
 Default = EID (Integer > 0 or <String>)  |
| S1, S2 | Scalar point
                                identification numbers. Default = 0 (Integer ≥ 0; S1 ≠ S2)  |
- S1 or S2, but not both, may be blank or zero, indicating a constrained coordinate.
 - Only one scalar damper element may be defined on a single entry.
 - A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
 - Scalar damper elements are ignored in heat transfer analysis.
 - String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - This card is represented as a spring or mass element in HyperMesh.
