CBUSH
Bulk Data Entry Defines a generalized spring-damper structural element.
Attention: Valid for Implicit and Explicit Analysis
CBUSH EID PID GA GB G0/X1 X2 X3 CID
S OCID S1 S2 S3
Example 1
Spring-damper element defined with default orientation and location; default orientation is only valid when only K, and/or K are defined on referenced PBUSH.
CBUSH 2 6 8 1
Example 2
Spring-damper location is offset from mid-point of GA-GB.
CBUSH 19 7 1 2 4
0.3
Example 3
Spring-damper is oriented by referencing coordinate system 5, and spring-damper location is explicitly defined using OCID, S1, S2, and S3.
CBUSH 41 9 1 2 5
7 1.0 0.5 -0.7
EID Unique element identification number.
No default (Integer > 0)
PID PBUSH entry property identification number.
Integer
Specifies an identification number for this property.
<String>
Specifies a user-defined string label for this property. 11
Default = EID (Integer > 0 or <String>)
GA Grid point identification number of the first connection point.
No default (Integer ≥ 0 or <PartName.number>) 6 9 10
GB Grid point identification number of the second connection point.
Xi Components of orientation vector V from GA in the displacement coordinate system of GA.
(Real)
G0 Alternate method to supply vector V using grid point GO. Direction of V is from GA to GO.
V is then transferred to End A.
(Integer > 0 or <PartName.number>) 3 9
CID Element coordinate system identification.
0
Basic coordinate system
blank
The element coordinate system is determined from GO or Xi
(Integer ≥ 0 or blank) 2 3
S Location of spring-damper as a fraction along the line segment between GA and GB.
Default = 0.5 (0.0 ≤ Real ≤ 1.0)
OCID Coordinate system identification for spring-damper offset. 7
-1 (Default)
Indicates that the offset is along GA-GB.
(Integer ≥ -1)
Si Components of the spring-damper offset in the OCID coordinate system, ignored if OCID is -1.
(Real)
  1. Element identification numbers must be unique with respect to all other element identification numbers.
    Figure 1. CBUSH Element
    Figure 2. Alternate CBUSH Element Definition
  2. CID > 0 overrides GO and Xi. Then the element x-axis is along T1, the element y-axis is along T2, and the element z-axis is along T3 of the CID coordinate system. If the CID refers to a cylindrical coordinate system or a spherical coordinate system, the grid GA is used to locate the system. If for cylindrical or spherical coordinate, GA falls on the z-axis used to define them, it is recommended that another CID be selected to define the element x-axis.
  3. For noncoincident grids (GAGB), when GO or (X1, X2, X3) is given and no CID is specified, the line AB is the element x-axis and the orientation vector V lies in the x-y plane (similar to the CBEAM element).
  4. For noncoincident grids (GAGB), if neither GO or (X1, X2, X3) is specified and no CID is specified, the line AB is the element x-axis. This option is valid only when K or K or both on the PBUSH entry are specified (but K, K, K, and K are not specified). If K, K, K, or K are specified, the solver will terminate with an error.
  5. If GA and GB are coincident, or if GB is blank, CID must be specified. If GB is set to blank, the CBUSH simulates a grounded bushing element.
  6. If OCID refers to a cylindrical or spherical coordinate system, then grid GA is used to locate the system.
  7. A CBUSH element, referencing a PBUSH property with a single stiffness term, is equivalent to a CELAS1 or CELAS2 element, only when the elements have zero length. A non-zero length CBUSH assumes rigid body connections from the connection points, GA and GB, to the spring-damper location, as defined either by S or the OCID and Si fields.
  8. Bushing elements are ignored in heat transfer analysis.
  9. Supported local entries in specific parts can be referenced by the use of "fully-qualified references" on CBUSH entries in the model. A fully-qualified reference ("PartName.number") is similar to the format of a numeric reference. "PartName" is the name of the part that contains the referenced local entry (part names are defined on the BEGIN Bulk Data Entry in the model). "number" is the identification number of a referenced local entry in the part "PartName". See Parts and Instances in the User Guide for detailed information on the use of fully-qualified references.
  10. The CBUSH element force is calculated as follows:
    F = K(UGB - UGA)
    Therefore, the sign of the force will depend on the grids GA and GB. If the grids are switched, the element force will be reversed.
  11. String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
  12. In large displacement scenarios, the element coordinate system also moves depending on different scenarios:
    1. If neither orientation vector V nor CID is defined and K1 > 0.0 in PBUSH definition, it co-rotates with GA—GB.
    2. If (a) is not satisfied, OCID is not defined and S = 1.0, it rotates according to the rotational DOF's at GA.
    3. If neither (a) nor (b) are satisfied, it rotates according to an average of the rotational DOF's at GA and GB.
  13. This card is represented as a spring element in HyperMesh.
