BCELL
Bulk Data Entry Defines a cell element.
| BCELL | EID | PID | GA | GB | JRID |
| BCELL | 6 | 6 | 233 | 223 | 10 |
| EID | Unique element identification
number. No default (Integer > 0) |
| PID | Identification number of a PCELL entry. Integer: Specifies an identification number for this property. No default (Integer > 0) |
| GA, GB | Connected grid points at ends A and
B. GA is cathode, and GB
is anode. No default (Integer > 0; GA ≠ GB) |
| JRID | Jelly roll ID, which is an element
SET ID. The element SET contains all elements of the
corresponding battery. The results related to the cell is
displayed on the jelly roll. No default (Integer > 0) |
- BCELL elements are working in transient electro-thermal analysis.
- This card is represented as a gap or mass element in HyperMesh.
