ASSEMBLY
I/O Options EntryDefines an assembly of parts which are included in the global model.
ASSEMBLY | GLOBNAME |
ASSEMBLY | Global1 |
ASSEMBLY | Activates the creation of an assembly of parts. | |
GLOBNAME | Name of the assembly
should match the name of the global part in the Bulk Data
section. (Character String) |
- If an ASSEMBLY entry is input in the model, then a minimum of one INSTANCE I/O Options Entry should be present.
- Only one ASSEMBLY entry can be present in a model.
- When
ASSEMBLY entry is present, the reading of the Bulk Data
section is different.
- Without ASSEMBLY entry, each part defined in the input deck is used in the model.
- When ASSEMBLY/INSTANCE entries are present, each part named on ASSEMBLY and INSTANCE entries are used, potentially multiple times, and parts with unknown names (which are not listed on any ASSEMBLY/INSTANCE cards) are skipped.
