Implementation
The simplified representation of a spot weld is used in HWTK GUI Toolkit to model the fatigue behavior at the weld.
A single weldment may contain a number of sections welded together with welds of different types. However, in this section you only look at analyzing the sections that contain spot welds. Refer to Seam Weld Fatigue Analysis for details about other weld types.
Simplified Spot Weld Representation
A spot weld is represented as a CBAR, CBEAM, CWELD, or CHEXA elements connected to two sheets of shell elements (PSHELL). The CWELD and CBEAM elements are equivalent to a CBAR element internally. The CHEXA element grid point forces are resolved as beam forces at the geometric centers of each face and then they are considered similar to other 1D elements for fatigue calculations.
Spot Weld Fatigue
The following sections illustrates how stresses and subsequently damage are calculated at each of the three locations shown in Figure 2.
Sheet Location (1 or 2)
At sheet location 1 or 2, damage is calculated at the point where the weld is attached to the sheet/shell.
The sheet location 1 is identified by the end A (grid GA) of the nugget (for 1D element nugget) and the face corresponding to the lowest ID’s of the nugget (for CHEXA element nugget). For the structure of CHEXA nugget, refer to Fatigue Input/Output.
The sheet location 2 is identified by the end B (grid GB) of the nugget (for 1D element nugget) and the face corresponding to the highest ID’s of the nugget (for CHEXA element nugget). For the structure of CHEXA nugget, refer to Fatigue Input/Output.
Radial stresses are calculated at the sheet locations by considering weld element forces at the attachment points. The radial stresses σ(θ) are calculated as a function of θ for each point in the load-time history as:
Where,
σ(fx)=κ(1.744fxT2) for fx>0.0
σ(fx)=0.0 for fx≤0.0
- D
- Diameter of the weld element
- T
- Thickness of the sheet under consideration for damage calculation
- κ
- Calculated as κ=0.6√T
The equivalent radial stresses are calculated at intervals of θ (Default =18 degrees). The value of θ can be modified by varying the NANGLE field . Subsequently, Rainflow cycle counting is used to calculate fatigue life and damage at each angle ( θ ). The worst damage value is then picked for output. A similar approach is conducted for the other sheet.
Nugget Location
The absolute maximum principal stresses are calculated using the shear stress and bending stress of the beam element as a function of θ for each point in the load-time history as:
Where,
σ(fx)=4fxπD2 for fx>0.0
D is the diameter of the weld element.
T is the thickness of the sheet under consideration for damage calculation.
The stresses are calculated at intervals of θ (Default =18 degrees). The value of θ can be modified by varying the NANGLE field . The equivalent maximum absolute principal stresses are calculated for each θ from τ(θ) and σ(θ) . These stresses are used for subsequent fatigue analysis. Rainflow cycle counting is used to calculate fatigue life and damage at each angle ( θ ). The worst damage value is then picked for output. A similar approach is conducted for the other sheet.
