Nonlinear Static Analysis
This solution sequence performs static nonlinear analysis. Static inherently implies that a process occurring in real-time is being simulated infinitely slowly.
This allows the equilibrium equation to be satisfied at each step and inertia, momentum effects are ignored. Therefore, the possibly dynamic problem can be solved as a static problem (static).
