Dynamic Aeroelastic Analysis is the study of the deflection in flexible structures
under aerodynamic loads, where the forces and acceleration are time dependent.
Flutter Analysis
Aeroelastic flutter is a dynamic instability of a structure associated with the
interaction of aerodynamic, elastic, and inertial loads.
Flutter analysis of aeroelastic systems involves determining the velocity (and hence
Mach Number) of the system and the frequency of oscillation at which the system
attains the state of flutter. In this phenomenon, the aerodynamic loads on a
flexible body couple with its natural modes of vibration to produce oscillatory
motions with increasing amplitude.
This may lead to catastrophic structural failure. Therefore, structures exposed to
aerodynamic loads must be carefully designed to avoid flutter.
In Finite Element Analysis, the prediction of flutter involves a series of complex
eigenvalue solutions. OptiStruct uses the modal approach
where the structural-vibration modes in a selected frequency range are used as the
degrees of freedom.
Flutter is supported for both subsonic (mach number < 1.0 and velocity in subsonic
regime) and supersonic (mach number > 1.0, and velocity in supersonic regime).
Transonic regime (mach number = 1.0) is currently not supported.
Methods
The four different methods for flutter analysis supported in OptiStruct are K, KE,
PK and PKNL.
For each of these methods described below, the complex eigenvalues () are extracted for a particular case, from which the
pairs of airspeed and damping (-), and airspeed and frequency (-) can be ascertained.
The precise form of eigenvalues differs for each of the methods.
For the K and KE methods, the eigenvalue is given
by:
For PK and PKNL methods, the eigenvalue is given
by:
Where,
Transient decay rate coefficient.
Circular frequency, given by .
K Method:
The philosophy behind the K method is to inject
the system with artificial damping (in the form of a structural
damping term) to push the system to the flutter point.
A set of complex eigenvalues is output at every combination of
density, Mach number, and reduced frequency from the
FLFACT entries.
For this reason, the results obtained from the
K method are slightly difficult to
interpret.
KE Method:
The KE method is a variant of the
K method with the following differences.
The viscous damping terms are ignored.
The complex modes are not output.
The flutter output is arranged based on modes and sorted
using an eigenvalue extrapolation technique.
These features imply that the KE method is a
computationally inexpensive and easy-to-interpret version of the
K method.
PK Method:
The PK method allows for a general flutter
analysis to be performed using doublet lattice aerodynamics
(that assumes simple harmonic motion) using an iterative
process.
In this method, the imaginary contributions to the stiffness
matrix are ignored. This means that structural damping terms and
modal damping with PARAM,
KDAMP, -1 will not be taken into account.
The eigenvalue extraction is carried out for every combination
of density, Mach number, and velocity from the
FLFACT entries.
An initial guess of the reduced frequency () is used to solve the complex
eigen problem whose output returns an updated reduced frequency;
the process being repeated until convergence. Modes are tracked
across airspeeds using the left and right complex eigenvectors.
PKNL Method:
The PKNL method is a variant of the
PK method designed with ‘no looping’.
In this method, the number of entries in the
FLFACT data for density ratios, Mach
numbers, and velocities need to be the same and the eigenvalue
extraction is carried out at each linear selection of density
ratio, Mach number, and velocity.
The following scenarios outlines the difference between the PK and
PKNL methods:
Scenario 1:
The flutter analysis is carried out at the following points:
(0.5, 0.3, 100), (0.5, 0.3, 200), (1.0, 0.3, 100), (1.0, 0.3, 200),
(0.5, 0.4, 100), (0.5, 0.4, 200), (1.0, 0.4, 100) and (1.0, 0.4,
200).
References the EIGC entry, for complex
eigenvalue extraction (K method only).
Problem Setup
The following content of an input file gives an example of a typical Aeroelastic
Flutter Analysis
setup.
$ SNIPPET OF AN INPUT FILE FOR AEROELASTIC FLUTTER ANALYSIS
DISP = ALL
SUBCASE 101
SPC = 101
METHOD = 102
FMETHOD = 103
BEGIN BULK
$--1---><--2---><--3---><--4---><--5---><--6---><--7---><--8---><--9---><--10-->
EIGRL 1 0.0 100. 4 MASS
FLUTTER 103 PK 1 2 3
FLFACT 1 0.4
FLFACT 2 0.5
FLFACT 3 150 -175 -200
$ If there are certain velocities for which flutter eigenvector output is desired,
$ in PK/PKNL methods, a negative sign can be added as shown above. In this example,
$ output to the result file will be available only for the velocities: 175 and 200.
$ See Output Section for more details.
AERO 102890. 2200. .123E-110 0
MKAERO1 0.5
+ .001 0.002 0.005 0.01 0.05 0.1 0.2 0.3
MKAERO1 0.5
0.5 0.6 0.8 1.0 1.5 2.0 3.0 4.0
$ other aeroelastic and structural entries
Output
Flutter Analysis Summary
The roots of the Complex Eigenvalue Analysis are printed in the .flt file. A typical flutter analysis summary in the
.flt file is shown below.Figure 2. Flutter analysis summary in an example .flt
file
For the K and KE methods:
The eigenvalue () is used to determine airspeed () and damping () using Equation 1.
Note: This equation
can be split into two equations for real and imaginary
components and the two unknowns can be solved.
When the values of are such that is physical (real), the calculated
values of velocity, damping and frequency are printed.
When the values of are such that is non-physical (complex), only
stability information is printed for velocity, damping, and
frequency values.
In such cases, when
g < 0
the system is unstable
g > 0
the system is stable
The determined values of in conjunction with the
user-specified reduced frequency () and reference chord length
(REFC from AERO
entry) can be used to calculate the frequency (),
Since the KE method arranges the flutter summary by
mode, the flutter point can be easily ascertained from a visual
inspection of when the damping switches signs.
For the PK and PKNL methods:
The frequency () and damping () are extracted from the form of the
eigen value using Equation 2.
Note: This equation
The
damping reported is:
In the case of purely real roots, the damping is:
The .flt file can be loaded into the “Flutter Curves”
functionality of the aeroelasticity module of HyperMesh to easily generate
the (-) and (-) curves without the use of any external
post-processing tool.
H3D Output
Currently, only the following output requests are supported with flutter
analysis. Refer to Aeroelastic Flutter Analysis for supported output formats.
SDISPLACEMENT - available only for
K, PK and
PKNL methods
The following table summarizes information on the eigenvector output for
different methods.
Method
K Method
Eigenvector output is available in the form of
points; each point corresponds to a reduced
frequency.
At a given point, the results are available for
each mode.
KE Method
Eigenvector output is not supported.
.h3d output file is not available.
PK/PKNL
Method
points; each point corresponds to a mode
number.
Output is not available for the positive
velocities in the FLFACT entry
for velocity.
If output is desired for certain velocities,
then in the FLFACT Bulk Data
Entry. An example is shown in the Problem Setup on this page.
This is only a convention; a negative velocity
has no physical meaning. A positive value is
always used for calculations regardless of the
sign of velocity in the FLFACT
entry.
