Aeroelastic Analysis is the study of the deflection of flexible aircraft structures
under aerodynamic loads, wherein the deformation of aircraft structures in turn affect the
airflow.
An overview of aeroelasticity, a version of the aeroelastic triangle, is illustrated
here.
Figure 1. Aeroelasticity Overview
The interaction between elastic forces and aerodynamic forces can be analyzed, as
part of the static aeroelasticity solution.
