I/O Options and Subcase Information
                    Entry Used in the I/O Options section or in frequency response (direct and modal) subcases to
        request acoustic intensity at the fluid grids.
            ACINT (format) = option
                            | Argument |
                            Options |
                            Description |
                            | format |
                            <H3D, PCH, blank> |
                                        - H3D
                                        - Results are output in Hyper3D format (.h3d file).
                                        - PCH
                                        - Results are output in Punch format (.pch file).
                                        - Blank (Default)
                                        - Results are output in all active formats for which the
                                            result is available.
                            | option |
                            <YES, ALL,
                        NO, NONE,
                    SID> |
                                        - YES, ALL (Default)
                                        - Intensity is output for all acoustic grids.
                                        - NO,
                    NONE
                                        - Intensity is not output.
                                        - SID
                                        - If a set ID is given, the acoustic intensity is output
                                            only for the fluid grids listed in that set.
                    - The expression for acoustic intensity
                        is related to the nodal pressure (
                            ) and the complex conjugate of the particle
                        velocity (
                            ), given by:
