When analyzing the vehicle, the components are divided into the sub-assemblies:
Body, Front wheel and
Rear wheel.Figure 1. Identify Part in SimLab
A sub-assembly is created for the selected components, to which the corresponding
material is automatically assigned in the background.
The front and rear wheels should be separate components. The wheel can either be a
single component or a combination of tire and rim.
Auto Vehicle Position
Analysis > Parts > Auto Vehicle Position
Using the Auto Vehicle Position tool, the vehicle is
positioned in the desired orientation relative to the channel based on the
coordinates of the channel and the dimensions of the front and rear wheels.Figure 2.
