This tool is used to create particles for bodies that are thin sections/sheet bodies.
The input geometry can be CAD or FE models. The particles are uniformly distributed
with a defined distance between neighboring particles in the global coordinate
system. A minimum number of layers of 3 of the particles are created inside the
volume. If the input body does not contain any closed volume, initially particles
will be formed enclosing the surface of this body and then particles will be added
to guarantee the specified number of particles.
The option Ignore Particle can be used to ignore the particle creation in the normal
direction of the selected faces.
