A technique where different structural components can be linked together so as to
produce similar topographical layouts.
To achieve this goal, a main DTPG card needs to be defined,
followed by any number of secondary DTPG cards which reference
the main. The main and secondary components are related to each other through local
coordinate systems, which are required, and through scaling factors, which are
optional.
Other manufacturing constraints, such as pattern grouping, can be applied to the main
DTPG card. These constraints will then automatically be
applied to the secondary DTPG card(s).
The following procedure should be followed to set up pattern repetition:
Create a main
DTPG card.
Apply other
manufacturing constraints as needed.
Define the local
coordinate system associated to the main DTPG card.
Create a secondary
DTPG card.
Define the local
coordinate systems associated to the secondary DTPG
card.
Apply scaling
factors as needed.
Repeat steps 4-6 for
any number of secondary DTPG cards.
Local Coordinates Systems
Local coordinates systems are generated by providing four points. These points can be
defined either by entering explicit coordinates or by referencing existing grids:
CAID
Defines the anchor point for the local coordinates system.
CFID
Defines the direction of the X-axis.
CSID
Defines the XY plane and indicates the positive sense of the
Y-axis.
CTID
Indicates the positive sense of the Z-axis.
The definition of the fourth point allows for both right-handed and left-handed
coordinate systems, which facilitates the creation of reflected patterns.Figure 1.
Alternatively, local coordinate systems can be defined by referencing an existing
rectangular coordinate system in the CID field, and by defining
an anchor point in the CAID field.
Note: If the fields defining
CFID, CSID, CTID,
and CID are left blank, then the global coordinates system is
used by default. The anchor point CAID, however, is always
required.
Scaling Factors
Scaling factors in the X, Y, and Z directions can be defined for each secondary
DTPG card. These factors are always related to the local
coordinate system. By playing with the local coordinate systems and the scaling
factors, a wide range of effects can be obtained as illustrated in Figure 2.Figure 2.
