TCURVE
I/O Options and Subcase Information Entry The TCURVE command can be used in the I/O Options section to define the plot title for XYPLOT output from a Random Response Analysis.
TCURVE = title
| Argument | Description |
| title | Character
                                    string. Default = A default title is provided.  |
- TCURVE may not be continued onto the next line.
 - A TCURVE definition applies to all
                    plots defined after until another definition of TCURVE
                    occurs. TCURVE. The following example would assign X-A, Y-A and the default plot title to the first plot, then X-A,Y-B and C-A to the second plot.
XTITLE = X-A YTITLE = Y-A XYPLOT (first plot definition) YTITLE = Y-B TCURVE = C-A XYPLOT (second plot definition)
