TABFAT
Bulk Data Entry Defines y values of each point on the loading time history.
| TABFAT | ID | y1 | y2 | y3 | y4 | y5 | y6 | y7 | |
| y8 | etc. | etc. |
| TABFAT | 1 | 0.000 | -0.601 | 0.968 | 0.515 | -0.263 | -0.090 | -0.582 | |
| -0.592 | -0.877 | -0.726 | 0.297 | -0.899 | -0.899 | -0.165 | |||
| 0.907 | 0.936 | -0.308 | -0.308 | -0.689 | 0.592 | 0.609 | |||
| -0.600 | -0.492 | -0.492 | -0.224 |
| ID | Unique identification
                                    number. No default (Integer > 0)  |
| y# | Y value of each point on
                                the loading time history curve. No default (Real)  |
- The TABFAT ID may be referenced by a FATLOAD definition.
 - This card is represented as a load collector in HyperMesh.
 - Prior to OptiStruct version 11.0, TABFAT was named TABLEFAT.
