Standard Result Outputs
If a result OUTPUT not defined, the default result output is both HM and H3D. If any result OUTPUT commands exist, there is no default OUTPUT type.
| Keyword | Description | Default Frequency | Affected Files | Options | Details |
| HM | Output results in HyperMesh binary format. | FL | *.res | <NODMIG, DMIGALL, DMIGSET> | Determines whether or not
                                to output results for interior points of external superelements.
                                    16
| H3D, HV | Output results in Hyper3D format. | FL | *.h3d | <BYSUB, BYITER> Default =
                                        BYSUB Note: Applicable to optimization runs
                                        only. | Determines the way the output files are arranged in an optimization run. 15 |
                                    16
| OP2, OUT2, OUTPUT2 | Output analysis results in Nastran output2 format. | FL | *.op2 | <MODEL, NOMODEL> Default = MODEL | Turns on/off the output of the model data to the file. 11 12 |
                                    16
| NASTRAN, PUNCH, PCH | Output analysis results in Nastran punch format. | FL | *.pch | <NODMIG, DMIGALL, DMIGSET> | Determines whether or not
                                    16
| *_s#.pch | <BYSUB, blank> |
| OPTI, ASCII, OS | Output results in OptiStruct ASCII format. | FL | *.cstr, *.dens, *.disp, *.force, *.gpf, *.load, *.mpcf, *.spcf, *.strs | - | For more information about the old and new OPTI formats, refer to PARAM, OPTI. |
| PATRAN, APATRAN | Output analysis results in
                                Patran ASCII
                                        format. (APATRAN uses an alternate file naming convention, with the iteration number after the file extension). | FL | *.#.#.#.dis,
                                    *.#.#.dis, *.#.#.els,
                                    *.#.dis,
                                        *.#.els, *.#.#.dis.#, *.#.dis.#, *.#.els.#, *.dis.#, *.els.# | - | - |
| HDF5 | Results are output in the Hierarchical Data Format, Version 5 (.h5 file). 22 | FL | *.h5 | <YES, NO, COMP, NOCOMP, SP, DP, BYPART> |
| NONE | Results are not output in any of the formats listed above. | - | - | - | - |
