SHAPE
I/O Options and Subcase Information Entry The SHAPE command can be used in the I/O Options section to request altered shape output for a shape optimization.
SHAPE (format_list, type, peakoutput) = option
| Argument | Options | Description |
| format | <HM, H3D, OP2 blank> |
| type | <ALL, DES> Default = DES |
| peakoutput | <PEAKOUT> |
| option | <YES, ALL,
                        NO, NONE> Default = YES |
- When the SHAPE command is not present, shape results are output.
- Shape results are only available for shape, topography, and free-shape optimizations.
- Outputting the shape results in all simulations allows analysis results to be plotted on the altered shape.
- The frequency of this output is controlled by the DESIGN keyword on an OUTPUT definition.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
- The shape contours in HyperView using the .op2 file are listed under Displacement Output and the design results are listed as Subcase 0.
